Ok
---------- I've ordered the bits for my hydraulic clutch from BURTONS but the info for calculation of the spacer required came via RACELINE 's Pete McKewan
He couldn't provide me with a kit as he uses only FORD stuff for which he's had bellhousing's made to suit . BUT
he did tell me what I needed to know --- in his words '' it's not rocket science mate ''
I thought others may want this info at some point so here's the proceedure ----------
1) measure the distance from the engine block face TO the gearbox bolting face(not the cover plate) This will be the bellhousing plus any spacers/gaskets you're using. In my case this is 180mm.
2)measure the distance from the engine block face TO the clutch cover fingers . In my case this is 91mm. Then add 5mm to account for clutch wear so's the clutch will never be parcially depressed . Total = 96mm.
3)180mm minus 96mm = 84mm (this is the exact length your new cover plate + hydraulic actuator + release bearing must be .
4)Now you can order the parts ------------- simply ask the supplier what his 3 components total length is when together
In my case from BURTONS it was 72mm . We already know the exact length required from (3)
SO --------- 84mm minus 72mm = 12mm spacer needed (or as close as you can get from their choice of spacers THEN machine it to the correct length ------------- BINGO sorted
In my case the spacer closest is 12.7mm .
Finally , once it's fitted , depress the clutch just enough to engage all gears then adjust the clutch pedal stop to suit OR you might end up taking the engine out again to refit the piston
In my case I've put a long bolt into the footwell with locknuts in front of the clutch pedal .
THIS is what I've been searching for ------ a nice simple formula
Well done and thanks Pete at RACELINE
and he didn't even make a sale to me
I hope this may be usefull to others in the future . Rob.
