We need to fit an oil cooler in the Stylus. Where can you squeeze them in? have through of in-front of the rad? what kind of mountings do you use? we have a 13 row Mocal cooler.
Oil Cooler Fitment
Re: Oil Cooler Fitment
Remind me what your engine spec' is Pete . Neither I nor Tim run one . His spec' is 225bhp , mine 200bhp and get plenty of GGGG's on track. If I fitted a cooler it would be mounted just behind the 'grill' with a decent gap between it and the radiator . Just make the brackets up yourself to go across from A frame to A frame preferably in alloy tube , say 13 to 15 mm.Pete&Matt wrote:We need to fit an oil cooler in the Stylus. Where can you squeeze them in? have through of in-front of the rad? what kind of mountings do you use? we have a 13 row Mocal cooler.
