Determined not to buy or hire a puller , I chose an 8 inch coach bolt then ground the head down to slip just passed the spigot to grab the edge. I pushed a 6mm bolt into the spigot beside the big bolt to keep it in position , grabbing the edge via it's ground down head. I had a piece of pipe handy about 6 inches or so to put over the threaded end of the coach bolt ---- plus large washer plus nut ------------------ wound away and out it came
Some of the bits and pieces to repair the master cylinder and hydraulic nose cylinder in the bell housing have arrived but I'm still waiting for flywheel and clutch bolts. I've got bolts for the bell housing to box , also the clever little NORDLOCK double washers and all gasket sets . Drained the box , cleaned and painted so all ready for assembling everything now.
Spent this afternoon cleaning all the box and hydraulic oil from under the car and tunnel and then noticed the powder coat peeling off from the engine side of the pedal box. Another little cleaning and bilthamber/paint job before it goes back together.
Flywheel arrived today with new ring gear fitted at £96 including carraige so with my other bits and pieces around £80 , I got away with it lightly
