connecting up my fuel tank filler and discovered it is sealed do I have to fit a breather to vent the tank to stop the possabilty of tank collapsing:?:
Cheers George
Fuel System
tank filler ?
Yes you most definately do George . Is it an aircraft type flush fit with a little butterfly hinge down flap over the lock ??
If yes , then drill through the lowest dip under the flap into the void. I took mine to bits to make sure I could see the direction of drilling (remove lock nut etc.)and to be sure no alloy dust gets into the tank when you put it back in. I used a dremel with the smallest drill in the kit --- about 2mm as I recall.
In case it occured to you -------------- NO it doesn't get any rain water through it and I've been in some real corkers of storms when I ran it in on the road. The little flap seems to sort it plus the hole's in a concave hollow filled by the convex flap
Rob(lots of people have told me they made a breather into the tank or filler pipe --- not worth the work)
- alecmartin19
car pic ?
Hey Alec , when you gonna put a little pic' of your beastie under your detailsalecmartin19 wrote:i've drilled a little hole in mine too. easy to do and no problems of water ingress so far! i've been out in a couple of storms too!
Rob.(some wa ----ker hit me towing the trailer today -- missed the cruiser but bust the axle , draw bar , wheel , tyre and springs on one axle --- £700 to repair and I need it to work
pic'
Werner Van Loock wrote:arranged something already for Alec. If you want some other, just let me know.
That was quick
Re: tank filler ?
It is a flush cap and did think about drilling it but was unsure about the water ingress problem but problem solved thanks for the infostylussprinter wrote:Yes you most definately do George . Is it an aircraft type flush fit with a little butterfly hinge down flap over the lock ??
In case it occured to you -------------- NO it doesn't get any rain water through it and I've been in some real corkers of storms when I ran it in on the road. The little flap seems to sort it plus the hole's in a concave hollow filled by the convex flap![]()
Cheers George
- alecmartin19
