Best place to get a hood
So the build it's nearing completion, it's off for body and paint on Monday (very excited!!!)
I'm going to need to get a hood for it. Does anybody know the price and quality difference between a hood from Tim and a Jill Judd custom hood?
Jasper
Jasper
Re: Best place to get a hood
All I do know is that if you go to Jill Judd , she will need the top rail that Tim supplies with the hood kit because he's the only one to have a pattern to fit the screenNissanman wrote:So the build it's nearing completion, it's off for body and paint on Monday (very excited!!!)
Jasper
Tim wants £465 for mohair, £395 for vinyl, which seems like a lot of money, but it does come with all fitting parts.
If Jill is quoting £200 for a basic half hood without supports then there's no way a full hood is going to be less than Tims as the back bit is the complicated bit.
How's the quality of Tims hood?
Jasp
Jasp
Quality
I don't have experience of hoods on my own car but this car I've just bought has a hood and I'd say it was good quality but poorly fitted. So much is down to the builder how it turns out. Before fitting my windscreen , I put an alloy bar around the screen edge glassed in BUT the key thing is to think ahead regarding hood fixing.On my own car, around the bar about 8 inches from each end of the screen , I folded a peice of thin steel like a sandwich which obviuosly got glassed in with the alloy bar. Then when you come to drill holes for hood fixing , the bolts won't wear through the fibre glass , leaving slots.
This is what's happened on the car I'm fettling
It's not a great driving experience with a hood anyway but a good emergency backstop. If I were making/fitting a hood from scratch on my own car then I'd make the middle hoop 25mm higher just to get the water running off better once parked. The hood is almost flat on this one. You could simply make the alloy plate higher and have two holes. Lower rear / higher middle hoop bolt. OR --- if the ends of the hoop are long enough -- drill another lower hole.
NEEDS thinking about before you rush to cut the material at the screen end -- take your time
colour ?
Come on then ------ what colour's it going to be
I need to see this little beast
and hear it
It's gonna be 1970's Japanese racing white, a nice cool off white, with anthracite grey stripes over the bonnet, and anthracite grey 5 spoke Classic Revolution alloys with polished rims, then the interior will be a combination of grey and black.
Not very exciting I know - but should have a nice retro look to it - with a bloody great modern Jap engine under the bonnet!!
The body work guy is as we speak trying to figure out how to do the bonnet bulge and wheel arches.
As soon as the wheels arrive (mid-May) it will be up to Surrey rolling road to have the ECU mapped and the boost controller set up by a man who knows what's he's doing (not me
Like these but dark grey...
So with that colour scheme , you're hoping to catch the opposition knapping
very sneeky y y
Are entrants required to disclose engine type in endurance events
rules ?
Is it first at the post wins OR a more complicated being on time --- neither early nor late
Navigator's job sounds a nightmare if it's the latter
