I think this one: http://www.peterlloydrallying.co.uk/ind ... uct_id=610
Anyway, since fitting these, I now get pad knock off when turning on full lock, so if I do a 3 point turn, I have to fully depress the brake pedal twice just to get the brakes back.
It took me a while to realise this was the issue, so whilst fault finding I:
Fitted a new master cylinder with brand new seals, fitted new rear pistons to shoes, flushed all the fluid many times(!), stripped and rebuilt front 4 pot calipers, added a bias valve to rear circuit, add a 10psi residual pressure valve to rear line and 2x 2psi valves to front lines, fitted new front pads, checked front discs for run out etc etc.
Having located the issue to the front hubs, I thought I'd welly them up (to the point the hubs would no longer rotate without a bar on them!) and then back them off again, this gave no improvement, so I tried again but leaving the hubs tighter (too tight for driving on) and still it happens.
Anyone else had this issue? My last resort is to go back to stnd front hubs. When I phoned Peter, he was less than helpful to say the least - couldn't wait to get me off the phone, just said that he'd never heard of that problem before!
Currently crying into my tea as I was getting Norma ready for Classic Le Mans next week and it looks like she'll not be coming with me
