RT rebuild thread
Re: RT rebuild thread
Nice planning work... its going to be good
I hope so! Long way to go yet though.MattD wrote:Nice planning work... its going to be good
I'm onto measuring and making some datums for the current positioning now - and working out which bits of chassis I need to move, as I have to widen the tunnel a bit to accomodate the Type9 properly.
Before I get back to grubby stuff, here's some shiny parts I picked up - heavy duty rod bolts will provide some peace of mind when playing with the rev limiter, and vernier pulleys to allow accurate timing of the non-standard cams I'll be fitting.
After some measuring and marking, I pulled the engine back out and put it to one side. I've decided I am going to get on with removing the main body tub, so set about removing the windscreen as the first step on that route. Tedious job, and I managed to crack it, so I guess I'll just have to get that new heated screen after all... Does everyone elses screen not fit the aperture very well at the bottom corners?
There are quite alot of rivets to be removed to get the tub off, and I figured I'd start at the front. Before doing so, I removed the outer pedal box which sealed up the gaps between engine bay and passenger compartment, and was affixed to the front firewall.
I soon got scuppered by access to the rivets around the front of the tub, I need to get a right-angle adapter to gain drill access. So I faced up to the less pleasant task of drilling out about 80 rivets on my back under the car, to get the side panels off between the chassis and the bottom edges down the sides of the bodywork.
Isn't it just Soooooo much fun though
In each corner of the bonnet shut gulley there should be a bolt/nut going through into the inner tub top , after that it's a cutting infill f/glass job on the dash inside etc .
I didn't think so at the time, though it beats sitting at a desk all day, maybe I should take a few months off to get it done.stylussprinter wrote:Isn't it just Soooooo much fun though![]()
Haven't looked closely but no bolt heads showing in the gutter. But I'm hoping I can get the inner and outer body off the chassis in one piece - it seems feasible at the moment.stylussprinter wrote:In each corner of the bonnet shut gulley there should be a bolt/nut going through into the inner tub top , after that it's a cutting infill f/glass job on the dash inside etc .
I'm not sure that's possible . When I built mine , the inner went on but then it took three people carefully stretching the bendy body shell to loop it over the rear then the front -- quite tricky not to break anything. If it stays all in the one peice I'm not sure you'll get it over the front dashboard/bulkhead metalwork
Worth a try though
You'll need a few spare hands when you're ready though
Worth a try though
But it is an RT with the front chopped off, so it should just lift straight offstylussprinter wrote:I'm not sure that's possible . When I built mine , the inner went on but then it took three people carefully stretching the bendy body shell to loop it over the rear then the front -- quite tricky not to break anything. If it stays all in the one peice I'm not sure you'll get it over the front dashboard/bulkhead metalwork![]()
Worth a try thoughYou'll need a few spare hands when you're ready though
There's a fair bit of clearance between body and chassis at the front...
Looks as though you've cut off the under wing body section that rivets onto the alluminium ledge , conected to the front chassis lower rail
I have removed the aluminium panels that join the bottom of the bodywork to the floor, if that's what you mean?stylussprinter wrote:Looks as though you've cut off the under wing body section that rivets onto the alluminium ledge , conected to the front chassis lower rail
Ah , I see . The original bodywork had f/glass right across that area so he obviously chopped it about a bit or one of the three owners did
To remove the rivets cant you use a sharpish cold chisel or old chisel and beat them off rather than drilling.
The windscreens are not a good fit, which is why the big transit rubber is used to cover the edges up. My screen had to be cut to fit.
You mean the classic, or RT bodywork had it? There are remnants of the classic body where it curved under and met the chassis, and was cut off for the RT conversion.stylussprinter wrote:Ah , I see . The original bodywork had f/glass right across that area so he obviously chopped it about a bit or one of the three owners did
Yeah I may be able to abuse them off, but I want to minimise damage to the inner tub, and I'm sure I'll need to do some awkward drilling at some other point anyway, so... excuse for a new tool! May well end up having to chisel or grind some of the least accessible ones anyway.kevp wrote:To remove the rivets cant you use a sharpish cold chisel or old chisel and beat them off rather than drilling.
Thanks for the info about the screen - the glass is wider than the frame by about 10mm at each bottom corner.
- pigeondave
- Are you a Stylus owner?: no
I just bought a heated screen from here
http://www.heatedwindscreens.com/acatal ... reens.html
I thought that the price was quite good, as I had another quote for a non heated screen for £180.
Don't know if you have a different supplier.
Nope, that's the supplier I had in mind. Any issues at all? I emailed Ricky about the wiring, to check it is a single element, whilst I am drawing a wiring diagram for my new loom.pigeondave wrote:Don't know if you have a different supplier.
hearbear
Thats the screen I got it has twin elements one on each half of the screen but he recommends joining the two half's together in series.DH2 wrote:Nope, that's the supplier I had in mind. Any issues at all? I emailed Ricky about the wiring, to check it is a single element, whilst I am drawing a wiring diagram for my new loom.pigeondave wrote:Don't know if you have a different supplier.
I will collect the carpets myself as coming to work in London for the week and that will pass an evening.
Cheers George
