Evening all,
I need to order a front ball joint and wanted a fisher one again rather than the original sherpa one. I cant remember the guys name or number, does anyone have it?
Fisher's new contact details.
Re: Fisher's new contact details.
His name is Steve and there's a post on the JPSC forum about him taking over Fishers plus a contact number . A few months ago but there if you look .
Not sure if this helps but I had to use Fisher wishbones on my car to replace a bent one and the ball joints are from a Land Rover, from memory I think they are a Freelander rod end. I am not sure that they will fit Stylus arms, but they are an improvement as the standard SSC wishbone has a tendecy to because of angle with the sierra hub to split the sherpa ball joint cover. The fisher wishbones from memory have some angle in them to reduce the angle the ball joint meets the base of the strut/hub.
- pigeondave
- Are you a Stylus owner?: no
Steve is at the same address as before but the phone number went with BGH Geartech.
http://www.furysportscars.co.uk/
Steve Hughes
Fury Sports Cars Ltd
Unit 8, Verrals Business Centre, Cranbrook, TN17 2AF
Tel: 01580 713 777
furysportscars@yahoo.co.uk
Steve Hughes
Tel: 01580 713 777
Hope it helpshttp://www.rgb-racing.org.uk/rgbbb/viewtopic.php?f=2&t=864 wrote:
for the Fury bits
here you go, plus some other bits he maybe interested in:-
Lower Balljoint Sherpa Drag Link
Quinton Hazell QH QR1774 RH Thread
Front Top balljoint Metro 80-84
Moprod MBJ860
Quinton Hazell QH QSJ1060S
Track Rod End Escort Mk 2
Quinton Hazell QR1384S
thanks guys. i spoke to steve, he hasnt got any ball joints in stock
