New headlight cover glass and New side screens
Posted: Wed Oct 17, 2007 11:52 am
Passenger side headlight cover or new style replacement headlights if there is such a thing.
Also, where can i get new side screens or is it easier to make them myself?
Can anyone source parts like the carbon dash etc or has SSC gone now?
Posted: Wed Oct 17, 2007 2:35 pm
by se7ensport
Make your own sidescreens, mine cost about £20 for the plastic, I just need to be bothered to make up the mounting brackets: they are basically 1inch "L" alloy same length as the top of the door with flat 1inch alloy strip to sandwich the window in place.
carbon dash, try this guy on locost builders: http://www.locostbuilders.co.uk/viewthr ... ?tid=73445
Posted: Wed Oct 17, 2007 3:17 pm
i have the old screens so would be easy to copy. There seems to be some kind of lip on the top of the door with little threaded rivet type things already, they fit in the holes in the plastic and almost protrude through the plastic, i assume that i can either get a strip of ali with matching holes and bolt it on sandwiching the plastic or just use larged headed bolts. Theres about 4 or 5 bolts needed so not a 2 second job to remove but nothing to major i suppose and better than getting wet..
Posted: Wed Oct 17, 2007 4:37 pm
by se7ensport
the fibreglass lip on the door is normally removed and replaced with the alloy "L" bracket as this can be adjusted to form an accurate fit when using a hood- if you don't have a hood it doesnt matter.
Posted: Wed Oct 17, 2007 7:18 pm
thanks for the info
i'll have to have another look, any ideas on the headlights?
Posted: Wed Oct 17, 2007 7:49 pm
by se7ensport
not sure on the light replacement parts, but depending on your glassing skills you could fit something like these http://cgi.ebay.co.uk/PEUGEOT-307-MORET ... dZViewItem
or headlights from an elise S2
http://cgi.ebay.co.uk/Lotus-Elise-S2-he ... dZViewItem
I've got VW Lupo headlights as they give great illumination and suit the shape of the car.
